The efficiency improvement of sun tracking is going to be related to location and time of year, and someone must have an app for a smart phone that would tell you what the available solar flux is for any given latitude and date. Anyone know of one?
guys... that latitude tilt recommendation is based on an AVERAGE for the YEAR for a FIXED panel! Unless you are going to spend the whole year in Baja and will not move the panel at all, a fixed latitude tilt is NOT the best way to go. In the summer you are much better off with a horizontal panel and in the winter much better off with a tilt bigger than the latitude angle. That is if you are going to leave the panel fixed the whole day which is not the best way to go anyway. If you want close to max power just point the panel at a point a bit ahead of the sun a couple of times during the day, and you'll come out way ahead.
added: if you want some numbers for context here you go:
take a 1 sq ft piece of paper, hold it at arms length in a vertical plane. It looks like 1 sqft when you look horizontally at it.
Now tilt it at 30degrees from the vertical. Now it looks like 0.87sqft.
Tilt it at 45deg it looks like 0.71sqft.
Tilt it at 60deg now it looks like 0.5 sqft.
So if your panel is off from the direction of the sun by 45deg you are losing 29% -about a third- of the max power you could get at that instant. Needless to say, the sun moves (apparently) a lot, by about 180deg in the summer, so want to bet you're off by more than 45deg more than just a little bit during the day if you are in a fixed position?
Plus as I said earlier, my panel was making 20V the other day just from pointing straight up at a cloudy winter sky. That's a good 90% of full summer voltage.
I'm surprised that panels are that different. That some need to be aimed and others don't.
