Cameras not displaying on head unit
  • Thread starter Thread starter EP1
  • Start date Start date
EP1
Intermittently, my cameras have stopped displaying all images which usually resets when I restart the vehicle. When the cameras stop displaying, all I see is a completely black screen. Has anyone else experienced this and is there an easy fix? Currently, the cameras automatically display every time I slow the vehicle. Thanks in advance.
Check the gray connector on the parking assist ecu. It's located above the plastic panel on the passenger side footwell. It's mounted horizontally right below the glove box. Aluminum case with the gray connector towards the center console. I had to reseat mine for that exact symptom on my '14.
This did not fix the issue unfortunately. Does anyone know where the camera ECU lives? Is it under the passenger seat? Any help is appreciated and I am almost certain it is a loose connector as it works sometimes. Thanks,
the parking assist ecu is the camera ecu
Here's a map, lol.
This recently started happening to my ‘15 LX. intermittently, both rear and side view cameras would be black screen (I figured it had to be ecu related since it was both cameras at the same time).
Pulling the grey plug, as mentioned above, got them working again; however, I’m not sure if this will be a permanent fix or not.
