I need to do the following and am hoping someone has done similar on a 100 series and can help me out. I’m not very electrically inclined so I may ask some stupid questions... the truck is a 2001 fzj100. I want to wire my aux driving lights to my high beams and have a single pole double throw switch allow the lights to come on independent of the high beams via one of the two on positions, with the high beams in the other on position, or off in the middle on position. I have read that the high beams are wire to ground instead of hot which doesn’t mean much to me other than the high beam wire in the steering column that I need to t splice into is going to read ground when I test with the hi beams on. I will seriously Venmo someone who helps me out in a clear and stupid proof way... I’m no wizard and this is supposedly a fairy easy job.
Please help fill in the steps...
1. Disconnect negative terminal from battery
2. Mount the lights and hook up to the harness via weatherpac and weatherproof splice connectors.
3. Mount the relay to a good ground in the engine bay and connect the other loose wire to the battery terminal
4. Run the switching wires through the firewall and then....
What do I do?? Remove the cover plates from the steering column to see the wiring loom for the headlights? Which one is it? Where does the t splice hook back to? How should the single pole double throw switch be hooked up?
Thanks in advance for your wizardry!!
What I have:
Auxbeam 80w led combo flood/spot lights that I’m going to install on my ARB front bar.
Auxbeam 2Pcs 7" LED Driving Light 80w Round LED Off-Road Light Bar 8000lm Combo Beams for Jeep ATV UTV Golf cart Lighting Trucks Pickup Ford f150 Work Light Amazon product ASIN B01EHKPW6K
I have a hella wiring harness for dual lighting applications. I’ll replace the single pole single throw switch and need to rewire the relay to make this work I think.
HELLA 357211011 ValueFit Two Light Wiring Harness Amazon product ASIN B016VAHX8E
I have a single pole double throw switch
DC Switch ON-OFF-ON single pole double throw Amazon.com: DC Switch ON-OFF-ON single pole double throw: Automotive
And a few of these connectors for connecting the raw ends of the lights to the weatherpack connectors on the hella harness.
IP68 Waterproof External Electrical Junction Box, ELifeApply Wire Connector for Underground Outdoor, Cable Range 4.5-9.5 mm, Shielded, Field Installable (4 Pack 2 Way 2 Pin) https://www.amazon.com/dp/B07MQDYBJ6/ref=cm_sw_r_cp_api_i_PS2NDb86DQNKD
What I have:
