084runnerltd
I should have taken pics, but I will use some pics from the web to help describe my issue...
I am in the process of removing the rear trailer hitch in order to install the slee rear bumper...and it didn't take me long to run into issues...
As I am sure some of you recall, there are 3 bolts per frame rail, 2 bolts near the rear, that run through the tow hook and one bolt further in, towards the center of the vehicle.
You can see the two outter bolts in this pic I stole from the web....
So my issue is that there are no bolt heads on the back two bolts that run through the tow hooks. I can see the captive nuts inside the frame...but no bolt head to grab on to...???
Then on the bolt that is by itself, toward the center of the vehicle, I got that one turning with a 3/4" breaker bar and with 3 feet of extensions...the problem is, everything is turning...the bolt as well as the captive nut in the frame rail.
I called it quits and drove the rig to a autoshop who has done quite a bit of work for me.
I have a feeling I am gonna get it back with no captive nuts...I can't blame them, but how do I install the bumper with all of the bolts and holes cut/drilled out??
I left the shop with the bumper install directions, but guessing that won't help...
Nothing is ever as easy as it first seems...
