Mine works well... but have had issues when I load it up and pull a trailer with the height defaulting to N if I try to raise the truck. I have new rear springs (OEM AHC) on order.
Keep in mind, this little study has a glaring flaw - "category-involved" guys (a.k.a. Mudders) tend (or trend) toward non-AHC versions. So, the non-AHC is very likely to over represent here.
Some one should start a business bringing those in. I bet people would buy them. I did... Ha ha
A lot of them weep a little, unless its gushing I wouldn't even worry about it, just top up the fluid once a year.2006 with AHC... Just had my 120K service done and was told it's $500+ to replace a weeping shock.
Planning to rip out the entire system and replace with a OME 2" with heavy duty springs to handle bumpers front and rear!
High neutral pressures will contribute to weeping from the shock actuators. Often it's self correcting - get the pressures down to their mid point within their respective tolerances and the weeping stops. Assuming the shocks arent damaged or the fluid is too old and crappy that is. I feel for people who pay through the nose to have weeping AHC shocks changed out if the root cause hasn't been addressed.A lot of them weep a little, unless its gushing I wouldn't even worry about it, just top up the fluid once a year.
Please explain what you mean about neutral pressures in the shock actuators. I don't work on these systems that often. So your saying that in the medium ride height setting the system pressure can be too high?High neutral pressures will contribute to weeping from the shock actuators. Often it's self correcting - get the pressures down to their mid point within their respective tolerances and the weeping stops. Assuming the shocks arent damaged or the fluid is too old and crappy that is. I feel for people who pay through the nose to have weeping AHC shocks changed out if the root cause hasn't been addressed.
Does it return to N while in park or after you start driving?
