[CA-ON] 80 Front window runs $120 shipped for both sides (4 Viewers)
A couple of threads were useful when I did mine--one to remove the door panel and the other had tips to do the install:
https://forum.ih8mud.com/80-series-...peaker-replacement-behind-stock-grille-4.html
https://forum.ih8mud.com/80-series-tech/554133-new-glass-run-yes-please.html
I did mine when it was warm out and soaked them in soapy water before installing them which made it easier to slide down the run. I just shoved it into the door as far as I could, then actually held on to the glass while rolling it down the window pulled the channel down. Might not have to remove panel if you do it that way, but it helped to see what I was doing and I was replacing my speakers too. I would also recommend leveling out the glass if yours has slipped down as it will still rattle a little if the glass is not fully secured in the channel. Changing them out helps a lot when the temps go down. I used to have to "help" the DS window up, but not anymore. Hope this helps.
Funny how simple some things are. It is very straight forward, but the runs do have specific sides for Rt and Lft so you need to take note. I've read all the threads I could find and there is no DIY thread. Door panel removal for my installation was a must. Pretty much cake after that. Basically the runs fit into a groove and you just push and pull to get them snug. I am AMAZED at the change in wind noise. This was worth it just for the faster windows, the reduction in wind noise while driving is like icing on the cake. Planning on rear windows shortly.
I read some threads about it, but i never seen a write up on how to change it. It is only .001:banana: job, so it is probably the reason why no one tried to make a writeup about it.
Anyways i have 10 sets arriving this week, for fast shipping i am taking preorders right now.
I will take a set.
Hi,
I need a front set only. Shipped to Winnipeg. PM sent. Waiting for total so I can Paypal.
All ordered window runs were shipped to people today from Michigan by Priority Mail USPS. So you should get them in 2 business days. Sorry guys i had a hiccup with the shipping from Canada. Shipping Internationally is not easy at low cost.
I have plenty of window runs in stock now.
I will take front and rear in about 2 weeks, if there is a back order list going
I currently have 12 full sets and i will be getting more in January, so no back order now.
Sent you an email. I'll take a front set
pm sent
