C4 vs Dissent front bumper—real-world feedback? (1 Viewer)
Tigard, Oregon
Three questions re Overland build for my white 2025 LC250 1958 edition:
Choosing between:
A) C4 Lo-Pro front + Dissent rear
B) Dissent front + Dissent rear
I need the front bumper so that I can add a winch.
And C), I need the rear bumper mostly because I need a tire swing out and am not sold on the hitch mounted swing outs. Dissent seems to be a top contender, along with the heavier Expedition One, and SLee tells me that they are still deciding whether they'll produce a rear bumper for the LC250 (sounds likely but will also likely be heavy).
Any reviews or comments on the Dissent rear bumper with tire swing out are welcome.
As for A) and B), who’s run either the C4 front or the Dissent front?
Let me know your impressions of:
• Build quality
• Functionality
• Effects on weight & MPG (C4 adds 10 lbs. & Dissent adds 115 lbs. up front, by my calculations, including estimated weight of removed OEM materials)
• Looks—does the C4 insert clash/stock bumper look clash with the look of the high-clearance, more sleek Dissent rear?
• Real-world pros / cons: winch access, sensors, rattles, customer service
Rig: 2.5″ lift, 35″ Falkens on Method 316s, Toyota stock roof rack, currently planning to add Westcott sliders and Slee aluminum skids. Haven't decided yet about an awning and RTT.
I'm concerned about growing curb weight and how ride and braking and MPGs will be affected. I already lost 3-4 MPGs when I added the lift and tires. Not the end of the world, but not ideal given the small gas tank.
I'm fairly new to this sort of build so appreciate your taking time to respond. Just learning as I build out a rig for overlanding and camping.
Pics or quick impressions appreciated—trying to decide if the matched Dissent front is worth the extra weight + $. Thanks!
I’d say it comes down to how hard you want to wheel the truck. Do you need rock protection + winch then dissent. If just a winch then C4. I’m sure I’ll end up with a C4 or one of the other center style bumpers at some point as I also want the winch for solo missions and winter extractions.
At the end of the day the less weight you add the better.
I like the look of the Dissent bumper as it removes basically the weirdest part of the LC250's exterior design scheme (weird plastic bumper wing panels). But it's pretty amazing that the C4 does not add any weight over stock. Also given the price delta, I might go with the C4.
I love the Dissent stuff. That said, it’s not just the 115 lbs you are adding. It’s 115 lbs plus the winch. I’d go C4 and keep it light.
I don’t have a dog in the fight, but another consideration might be the DV8 centric bumper. It comes powder coated. The C4 is bare steel.
