Part arrived as well as Harbor Freight forceps. I do not see how it is possible to do this without the 12" forceps - for $5.99 it is a must have.
1998 TLC 240k broken off in ACC/ON, battery dead after a few days.
Using the improved procedure since Post #33 and YT Video...
I did not remove the seat. I put two boxes outside cab and just laid down into footwell.
Picture of my rod as broken
I forgot to take picture of the broken piece's position but the steering lock pin was already pushed out to the right - it was not in the way.
I did not remove the black vent below steering wheel to get to the screws of the white round plastic sensor. I did not find it hard to reach with screw-driver from behind.
I first tried to back off the white round plastic sensor only 1/8th". This was not enough. My broken rod would not rotate counter-clockwise. I could rotate only clockwise 90 degrees (which also released the steering lock pin making it in the way). Versus the YT video, the 12" forceps have rounded tip and they pushed lock ping out of the way while grabbing rod. When I rotated rod back counter clockwise to found position - this also moved the steering lock ping back out. Shrug.
Even 3/16" wasn't enough.
I then carefully backed off the sensor by 1/4" inch. Only then could it rotate broken piece counter-clockwise 90 degrees and came out easily with the forceps.
The steering lock pin was released again while removing the broken piece.
I put the new rod in as described (12 oclock). I do not believe I was able to turn it counter clockwise to seat the slot of the rod end as described. This may have been a mistake. I then turned it clockwise and it felt solid - turned to 3-5 oclock'ish and settled on 4 oclock as prescribed.
I found that tightening the screws was harder than I expected. I believe if you feel you may not have the rod slot seated correctly. At a point near fully tightened the sensor screws I heard a snap sound and a round white tab popped off the back of the sensor - about the size of paper hole punch-out. Ugh.
I think I had goofed and noticed that the brass tab was now at 3 to 3:30. I tested the play of the rod - it was not moveable. I decided to loosen the sensor again and once I had backed it off about 1/8th", with my finger on the rod, I felt/heard a click. Clearly the rod had now seated itself correctly in the sensor. I turned the rod back to 4 o'clock and tightened the sensor screws (which were also easier to tighten).
The rest of the procedure worked fine. Once I had the black/clear ring screwed in and plugged in I jump started and steering turned freely when ON.
I will do preventative fix on 05LC once my back feels better.
Very thankful for the procedure from this community.
