uh, no. I am, by FAR, the world's slowest mechanic.... but then again I do things so much slower than the times others post - I swear that It takes me about 2x as long as the longest mentioned by anyone for any repair - am I the only one???!
well, today as my wife is leaving, she complains that she turns the key and nothing happens. I go out to see, and it seems like the ignition or tumbler has borken off in the "off" position. Turning the key does nothing, cant even get accessory power. I now have to tow it in to my mechanics for him to look at it![]()
Not overly common but have seen quite a few. The shaft behind the ign lock cylinder has broken. The shaft connects the lock cyl to the electrical part of the ign switch and also controls the mechanical steering lock. Two ways to fix - same parts involved.
Parts needed, Steering column collar (piece that ign lock cyl fits into)
2 break away bolts.
need to remove the ign lock cyl, and elec ign switch. You can either fineagle the shaft out of the collar housing and fish it out of the new on and reinstall or remove the whole collar. Need to chisel out old break away bolts and remove collar. Be careful on LX models because it is very easy to get the tele steering guides all screwed at this step.
hope this helps, ben
I joined the "busted ignition" club this past week. 2001 LX470. Same exact issue with broken camshaft in steering lock assembly. I searched around, and did not see any videos for this fix. So, I decided to make on with my brother. Here's the youtube link:
I hope this helps anyone doing the repair themselves. I also included the PNs in the text.
Thanks to everyone on this post who guided this repair. Saved me hundreds of dollars.
Thank you for this!
This just happened to my TLC while my wife was using it for work. I know this is an older post, but can I just order the camshaft part or do i have to replace the whole ignition cylinder? Do you have the part number by chance?
Gator!
If you look at the comments to the youtube video, one person did find a site that sells only the camshaft instead of the entire assembly. However, the picture on that site showed the weaker version (i.e. the one that will break again), and the price was roughly the same as buying the entire assembly. Unless they can confirm that it's the new design (i.e. the stronger one), I would avoid them, and just get the assembly. I got mine at parts.com, but I'm sure there are multiple places to get them (like ranma21 who posted right aboveThank you for this!
Gator!
Sorry if this has been asked before, but are there specific years of 100 series affected? I have an 03.
It happened.
'03. In my drive, luckily in the off position. It is my only vehicle, so I didn't have time to order from the UAE to get another skinny one.
Tried multiple online sites, none had it in stock but if you have time you can get the whole assembly for about $237. I couldn't wait for them to order, and then ship to me so I bought from the local Toyota dealer for $309.
Only reason I'm posting is because I had a heck of a time with limited tools trying to fish the broken chunk out. So while I was dreading taking the back piece off , I had to. If you are careful, and hold that assembly up, you can take that back piece completely off instead of just loosening the two screws without it spitting the little pieces in there out. Once that was out of the way, I was able to get to and help push out the broken cam from the backside in 30 secs.
I plan on ordering the $22 part from the UAE, waiting the two weeks for it to get here, and put in the $300+ housing, and sell it on Ebay for the $230 or so these are bringing....
