Burning Plastic Smell
Charlotte, NC
The Car: 2006 Lexus LX470, ~120k miles, timing belt done, all other scheduled maintenance done.
The Problem: Wife is driving it today, gets home and says "It smells a little like burnt plastic." My sense of smell isn't the greatest but I detect a faint odor of what I associate with burning plastic, not rubber. Her sense of smell is much better, thinks is coming from the radiator area. I look at the fan, tubes, pipes etc, don't see anything. Coolant is full. I go back inside and close the garage and when I go back out 10 minutes later the smell is very strong. Definately something plastic burned/melted. I can't see anything.
Any suggestions?
CEL did not come on.
Only light on is the TPMS, been on for a few days, blinking so I think I need new sensors.
I can probably take it to the dealership or a local shop that does a lot of landcruiser work on Monday. I'm not what we would call a "wrencher"
Update: While no mechanic, I opened the hood, turned the truck on, rev'd it in neutral, could not get any additional smell, checked under-carriage, no stuck plastic bag (A suggestion from a previous thread) Going to go for a little drive (To the lindt chocolate store, if there is a local who knows my problem there could be some headed your way).
Look around the manifolds and check to see if any hoses/lines came loose from clips that caused them to touch. Take a good look at the battery terminals, as well.
Do you have the plastic engine cover on? It may be coming in contact with the manifold somewhere and melting it. Also check your exhaust pipe. My father drove over a plastic Walmart bag a few years back in his Camry and it stuck to his exhaust causing the smell of burnt plastic to seep into the cab.
Rodent in engine valley perhaps, cook to d$%th and nothing left!
LMAO... I would not want to smell or clean this!
I'm guessing the rodent thing is right. If not in the engine intake valley then somewhere the nest stuff got hot. Get out the shop vacuum and look around.
Many moons ago I had burning plastic smell that turned out to be a plastic grocery bag that I had run over and it instantly melted onto the cat. That little gift kept on giving for quite a while.
