Did you guys see this? $600.00 for a burnt fj40. Might seem like a joke, however I have bought 2 burnt fj40's in the past and it worked out pretty good both times. If I was closer I would consider this pending visual inspection. The tub actually looks really straight. From experience the front cowl panel and dash might have a little warp from the heat. After blasting the tub it will probably look pretty good. Might be worth checking out if you are close.
1972 Toyota FJ40 BURNED
