2001LC
The caliper is somewhat of a fail-safe if wheel bearing nut fell off. It will hold wheel hub on axle. It's kind of locks rotor disk in which is attached to wheel hub.
Found a yard in southern VA that sent me the whole assembly (knuckle, hub, etc) for $105 shipped, in really good shape, paint on the knuckle was still kind of shiny! Worth every penny. Ended up replacing the boots on the upper and lower ball joint, both wheel bearings, rotors, pads, calipers. Seems to drive great so far.WOW the two bolts holding on caliber are hard to bust. Not something I've dealt with, but assume they're not only corrosion issue with knuckle bolts & speed sensors. Interesting this may be why 200 series FSM calls them non re-usable. I feel for the rigs in the rust belt, PITA!
If overall condition of knuckle is bad. I'd be inclined to replace steering knuckle.
