I'm prepping to do the same soon. I just took delivery yesterday of a set of nice shiny brake lines from
SDHQ, I also have Speedbleeders to install. I've already done new pads and DBA rotors.
I don't have Techstream anymore (laptop died). I do have a nice pressure bleeder with an adapter for the reservoir, so I'm just gonna go that route. You could also just do the "pump the pedal" method.
Follow up. Got these installed yesterday. I replaced all the lines at once, waited until they were all done to bleed.
Note these lines are a little longer, but only in the rear center 2 lines. The fronts are only about 3/4" longer, not much, but that makes sense given the travel of the IFS suspension doesn't change, even with a lift. I have OME rear coils and BP-51 suspension, about 2" of lift.
Other notes, in case someone is planning on this upgrade:
The banjo ends do not have the little "ears" on them to keep them in proper alignment when tightening the banjo bolt:
Similarly, the other ends that fit into the brackets at the hard lines don't have the "flats" that engage into the bracket to keep the hose from spinning while tightening the flare nut. I used an 18mm open-end backer wrench to hold it from turning.
The longer lines in the rear take care to get them installed with a slight "corkscrew" so they don't rub on the gas tank or the UCA. This is how I got them installed, but the truck is still up on the lift, axle drooped:
Make sure you check that they are not rubbing on anything when you get it back down on the ground.
I didn't bother plugging the lines when they were open, here's how I did each line. I used a Harbor Freight line pinch clamp on the OLD line about mid point, then I broke all the fittings slightly loose. I removed the banjo bolt, cleaned the threads out to make sure no dirt entered the caliper (I actually pulled each caliper off and dumped out the old fluid, just to be thorough), then attached the new line at the banjo bolt, snugged tight. Then I quickly removed the upper end, first the little clip then the hard line flare nut, and quickly stabbed the new line on to the hard line. I doubt I lost more than a tablespoon of fluid at each connection, just put a catch pan under and be ready with tools and a rag, go quickly. I draped an old plastic bag on the front suspension to protect it from the spilled fluid (eats paint off!), this helped a lot with the mess. Oh yeah, I also swapped all the old bleeders out for Speed Bleeders (#639560). It is surprising how difficult it is to get 22 ft-lbs on those banjo bolts!
Front line all installed (pass side):
Bleeding: I first did the "pump the brake pedal 40 times" thing to empty the accumulator, no idea if it did anything. Then I had a helper (GF) pump the pedal for the front calipers, then the ignition-on hold the pedal part for the rear calipers. Everything went as it should, I ended up using right around 2 quarts of fluid.
First impression: not a huge difference, but they brakes are a little crisper and engage slightly quicker. I didn't swap pads or rotors, they were all still in good shape (DBA rotors and Hawk Super Duty pads). Maybe next spring I'll treat it to new pads.
Truck goes in for new tires and alignment next Tuesday (Michelins), then I gotta reinstall all the skids, so I'll change the oil and bleed the brakes again, just to be sure I got all the air out.
