Does anyone know where to find a good brake pad DIY guide for a 95 80? I'm a little of a rookie when it comes to brakes. Thanks!
I'm thinking you may not be aware of the 80 Series FAQs? Sticky thread at the top of the 80-Series Tech section:
https://forum.ih8mud.com/80-series-tech/84888-faq-80-lx450-aug-2010-added-hood-vents-louvers.html
LOTS of valuable and helpful information in there including links to the thread arndog linked to and this one:
https://forum.ih8mud.com/80-series-tech/81098-brake-flush.html#post962781
Personally, I'd get at the very least the Haynes manual but preferably the Toyota FSM.
That said, assuming you don't have any other issues, replacing the front and rear brake pads is a pretty simple job. Of course if you run into other issues that simple job could get a lot more involved.
Things to consider are do you need to have the rotors turned? If so, then try to find a local brake place that can turn the rotors (at least the fronts) on the vehicle. Here in Colorado Brakes Plus can do that. Removing the rotors is a LOT more involved and if you get to that point you might as well just go ahead and do the full
front axle service because you are 1/2 way or more there. Sucks to do things twice if you can avoid it IMO.
Usually when you muck with the brakes you end up needing to bleed them. Not difficult with the right tools (buddy to do it the manual way or a power bleeder for one person operation,
flare nut wrench, etc.) but the 80 series brakes can be difficult to bleed for whatever reason.
I encourage folks to wrench on their own rigs and learn. I had never replaced brake pads, bled brakes, replaced rotors, etc. until a couple years ago. But, stuff doesn't always go smoothly so if you aren't up to tackling potential problems you might be better off just taking it to a reputable shop. Heck, some places (in CO at least) offer free lifetime brake pad warranties and 80s eat front brake pads...You typically still have to pay for the labor each time the pads are replaced but maybe that is the best avenue for you to take. In CO I always had good luck with Midas with my other cars till I bought my 80s and started learning to do the work myself.
