Brake Line Flaring - Procedure + Questions
As were those on my 81. I don't think Toyota used bubble flairs at all. I can't explain the shouldered vs. non-shouldered fittings, but I also don't think it matters.
I'm inclined to agree. As long as you can get sufficient thread engagement in the shallow holes with a shouldered nut, I don't see any reason why they wouldn't work.
The only possible difference with those shouldered nuts would be the nipple inside the female end - brake cylinder or caliper , ect . There are variances in how those nipples are shaped and that's probably the reason for a difference in the male line ends .
Again, speaking from a position of complete ignorance when it comes to brake lines/flares, I would think that all the nipples in the female ends would have to be 45 degrees, by definition of a double flare - would they not?
they are 45deg flares.
Hey how y'all doing, greetings from Costa Rica.
So... on monday my clutch went bad, diagnosis = bad clutch MC. Loss complete clutch pressure, I tried flushing the system and completely black brake fluid came as a result, and still no pressure. (when I restored the system 2 years ago, I used SOR's repair kits on both MC's) And I had a revelation, what if I change all the clutch and brake system? Because when the dang thing went I almost crap myself, and also made me wonder if the Brake MC would do the same some day.
My 25 has the original copper lines I think, the problem is, and also what is keeping me up at night since it all happened... is that my lines are all bent and mangled, maybe result of bad maintenance over the years (no holes or leaks so far).
So I am going to tell you what I got and what I -hypothetically- would do to change the whole system (of course will keep all the original parts maybe resleeve the MC's in the future for when I fell like going back to the dark side). Hopefully you can tell me your insight, problems that I am not seeing, better solutions, and so forth.
What I got:
BRAKE SYSTEM: Original MC (casted reservoir) joined by a 13 mm fitting to a 8.51 mm copper line (9mm? I measured with a caliper) which in turn joins again with a 13 mm fitting to the front distribution block, from there is all 11 mm fittings but with a 6.42 mm line (7mm?) to each of the front slave cylinders, and a line (again 6.42mm in diameter) that goes to the rear distribution block with again 11mm fittings, again to each rear slave cylinder.
CLUTCH SYSTEM: Original MC (Tin Can reservoir) this one joins with a 11mm fitting to a 6.42 mm copper line (7mm?), that joins to a new adapter (from 11 mm to 10 mm) to a hydraulic hose from SOR and their replacement Clutch Slave Cylinder.
What I -hypothetically- would do:
BRAKE SYSTEM: OEM Toyota MC For FJ40 58-7/70 (change the cap on it as I saw in another thread to repurpose the brake pressure switch), NiCopp 1/4" line with M13 x 1.5 fittings (from InlineTube.com) to the first distribution block, and for the rest NiCopp 3/16" line with M11 x 1.0 fittings.
CLUTCH SYSTEM: Aisin CMT-014 MC, to a NiCopp 3/16" line with M11 x 1.0 fittings, same adapter, same hydraulic hose from SOR, and a Aisin CRT-012 SC.
What I am still not completely sure is the threads on those M13 x 1.5 fittings, not sure if they will fit the distribution block.
So what do you think, crazy?, I did something wrong?, any bit of info or criticism would be helpful
Thanks in advance.
What I got:
Thanks in advance.
I have re used the stock flare nuts on new lines and home made flares with great success. ( Provided they weren't mangled when removed)
Another thing I have come to learn is a flare is not 100% complete until it is tightened into its counter part. I have a double female fitting that I use on the bench to complete the flare so I can inspect it before installation.
What I got:
Thanks in advance.
Just so you'll know, all the brake line nuts were M9 x 1.0 through 6/70. In 7/70 they started using M10 x 1.0 nuts. All are 3/16th line and use double flares. If you have adapters installed on your truck at the ends of the lines, it's not original.
STEP 6:
With the adapter REMOVED, re-align the clamp. Twist down the cone on the clamp into the inner diameter of your tube. I lubed the clamp-cone with brake fluid here as well.
This results in your final, double flare.
Great write up, and thanks for posting. Turned into a very informative thread that helped me immensely. Appreciated!
glad it helped! This was a valuable learning experience for me too, when I did it. Hard to believe it was almost exactly 7 years ago...I though my truck would be done by now 😂
