Read all threads. Similar problem to some but hoping I'm missing something. OBDC scanner doesn't do ABS codes unfortunately. Failure came on suddenly; no prior issues. Lights and alarm now; no brakes. No pump action; only the ABS Mtr2 relay in the fuse box under the hood clicks intermittently with key on. Assume that means the actuator pump is switching on but not working. Have the FSM out now and jumping pins to decipher blinking lights\codes. Seems like most have sucked it up and just bought the new unit at the dealership. This is our DD so not a lot of time to diagnose so help is much appreciated. Only one dealership locally so not a lot of leverage.
Edit: 100 has about 145K on the clock with slotted rotors and fancy pads 1 yr old (thanks Cristo)
