Brake Dust Cover Part Numbers
FamilyCamper
Richmond, VA
Was changing my wheel bearing out the other day and came across a couple rust holes in the inner spindle dust seal. I originally thought this was the dust cover (part #s below). Turns out the part I actually needed was separate and is the inner dust seal. Had a hard time finding all the part numbers needed so here is a list of everything.
Brake dust cover (large part you see easily that is between the rotor and knuckle)
Driver 47782-60110
Passenger 47781-60110
9031399001- Inner Dust Seal (on the outside of the larger dust cover and seals the gap between the spindle/hub)
4343660020 - Knuckle Spindle Dust Cover Gasket (this goes in between the larger dust cover and inner seal)
9008011370 - Bolts x4 that hold the dust cover/seal onto the knuckle.
All parts are interchangeable between sides except for the larger dust covers.
update - this what what my dust seal looked liked and I painted my knuckle with Eastwood rust encapsulator while I was doing the job. Very happy with the outcome.
Driver 47782-60110
Thanks for sharing this! Had a bolt back out of my hub and it beat around in there and absolutely destroyed my inner dust seal.
Great work finding this, as I know it wasn’t easy!
