I pulled the battery from the Ford 2N this afternoon. I didn't like what I saw. Dry cells and 0 volts. Still, I would like to try and see if the battery will take a charge. My battery charger is 12V only. Anybody have one I can borrow?
When I pulled the battery it was hooked up wrong. Should have been positive ground and it was hooked up as negative ground. Plus, it had a plastic cap on the "-" terminal under the cable clamp. Odd. I filled up one cell with water and it was so dry I'm wondering if the battery was ever filled with acid. I think I'll do some shopping for acid. The plates were very clean.
Tomorrow I'm going to jumper the starter and see if it turns.
