Is a BMC required to run 285 tires with an Eibach 2.5 Lift?
285 65 17“285” is not a tire size - more info please.
285 65 17
Sorry that should have been 285 70(maybe75) 17. I feel like 90% of the lifts are between 2-3" and almost everyone runs this tire setup? The reality is the truck will be a pavement princess 99% of the time so I cant see wanting to go bigger.Just looking up the stock tire size for a GX I found the following:
Stock 2019 GX460: 265/65 18 = 30.5"
Your suggested size: 285/65 17 = 31.6"
I would think that you could probably stuff that 285/65 17 on your rig with stock suspension AND it will definitely fit with a 2.5" lift!
Remember, you're only talking about .55" (a little over a half inch" ride height).
Do it and call it done!
One last thing, are SURE that is the largest tire size you'll ever want to do? Just be sure you're getting the right suspension lift. it's an expensive mistake if you decide to go with a much larger tire and realize that you needed a higher lift.
If this is truly to be a "pavement princess", take into consideration what is the maximum size spare tire that will fit in the stock position under the rear.Sorry that should have been 285 70(maybe75) 17. I feel like 90% of the lifts are between 2-3" and almost everyone runs this tire setup? The reality is the truck will be a pavement princess 99% of the time so I cant see wanting to go bigger.
With no lift and 285/70 17s, I could use a BMC even for not-that-sharp turns on the streets. It's driveable and doesn't lock the wheel by catching, but it scrubs good. Wheels are 17x8.5 with -10mm offset.
With a 2-3" lift, the wheel goes backwards, more towards the BM, so the need for a chop grows. With new UCAs with 3-4* of additional caster built into them, you return more towards the no-lift situation of probably needing one for most people's use of the rig.
This is based on my experience only.
I'm fairly close to 3" of lift with a 275/70 tire, 17x8.5" +10 offset wheels and SPC UCA's. No BMC. Rubs a bit only when aired down to 18 psi at full lock in reverse. All probably depends on tire size and type of wheels.
