Tuck that back up or cut out?
No one asks how or why this happened?
Partially drop the headliner, cut them, buy new ones, re-install and you are done.
It also looks like your driver seatbelt pretensioner is toasted too. Replace that also
Remember to disconnect the battery during the process.
A few bolts and connectors. There's not much to itIs installing the new ones relatively that easy?
Im not sure what was the cause of the airbags to deploy but as soon as they get replaced you will have to scan the vehicle and check for codes.Does it run without a code? Did you have to replace the airbag ecu, or reflash to remove crash data?
I’m planning to cut out but is there any downsides to this? If I was to repair in the future will this have an impact?View attachment 2964368View attachment 2964369View attachment 2964367View attachment 2964366
I’m planning to cut out but is there any downsides to this? If I was to repair in the future will this have an impact? What we need to find out is if I repaired in the future do they need to use the now curtain airbags
