Lookin good mate, it's going to be a beauty once done, hats off to you
The batteries have to be connected in series
Ground (- battery +) ----> (- 2nd battery +) to starter and fuse box
There's a jumper from the + of the first battery to the headlights if it's a US spec cruiser, but if you're using everything BJ74, then you don't have this jumper.
The jumper from battery 1 negative to battery 2 positive should be at least double ought '00' gauge with the distance between the batteries in your case.
Now I am having trouble locating the *^%$ bracket for the throttle cable on the engine.
Frustrating
Just that one, or should all the cables be 00. I'm making all new anyway
78184B BRACKET, ACCELERATOR CONTROL CABLE
78184-90K01 (11/1984 - 07/1986) 1 $20.76
78184-90K03 (08/1986 - 12/1989) 1 $28.07
new is cheap, try Akella4X4
All the battery and starter cables.
If you want to prevent starting, there are easier ways to do it with the vacuum system. The starter relay is easy to bypass, and most people know how, very few understand the vac system. PM if you're interested, I don't post that info on a public forum.
