Bj73 Pic.... (1 Viewer)
PIAA said:
In Malaysia Most L/c Is Using Diesel Engien From 13bt -14bt - 15bt .
For My Self Is 14bt And I Convert My Suspension To Coil Spring Front And Rear.
-doulble Shocks Front And Rear
-axle Hzj80 Front And Rear With Arb Locker
14B-T mmmmmm I like it ! with gearing, stock 80 series . ? 4.11 . ?
I thought 14B-T pulling 130 - 135 HP .. ? nice ! :D
PIAA said:
roscoFJ73...
HZJ80 FRONT AND REAR COIL SPRING .
Bigger pics would be nice:D. Try the image resizer free from Microsoft
PIAA said:
AXLE RATIO IS 10.41 !
TRY IT !!
HOLY SH*# 10.41/1. i would love to see the ring gear...
<of course i know you are saying 10 pinion teeth to 41 crown teeth but i thought this was fun>
14BT IS POWERFUL ENGINE ,IF YOU CAN TUNE THE FUEL PUMP CAN MADE IT DIFFERENT !!
TRY IT !!
Dude .. I know exactly what are you saying .. you need to look my 2H EGT numbers .. :D
HI MATE !!!
THE GEARING IS 4.1 !
14BT ENGINE IF YOU TUNE UP ,IS MORE THAN 180HP !
180HP?? :eek:
PIAA, what about torque?? I'm more interested in the torque value. Standard (read "pre-tune up") 13B-T pulls 210 ft/lbs.
I assume standard 14B-T pulls in excess of 250 ft/lbs??:confused:
Cheers!!
I know this should be in another discussion but can't help it:whoops:
Tuning up Fuel Pumps will reduce EGT ONLY if the engine is turbocharged (more fuel needs more air). Too rich or too lean will increase EGT.
Tuning up fuel pumps includes adding external and changing internal components in the pump itself to accomodate more flow and pressure. This is especially important if you're turbocharging a stock NA diesel engine. :cheers:
Hello PIAA
Can you pls put more pics of rig's suspension? seems to me like you have a dual shock set up, i am contemplating the same, so your help and input will be much appreciateed.
Hi PIAA,
which part of M'sia are you from,l am from Sarawak.
Nice truck
Simon
Winnipeg
Hi PIAA,
Great Middy, am in Australia, would love to know more bout yor suspension setup. Am looking to d a coil conversion on mine. Have been trawling the internet for ages trying to find info about it. If you could send some pics and info on your setup, it would be greatly appreciated. my email is vdclee@yahoo.com.au
Sorry, I would like know if it's possible put on ours BJ73 30 spline kit of Bobby long... I tried ask to bob many years ago but he wasn't sure so we did do nothing
I believe that the 7* series axles are shorter than 80 and 60 series and larger ( wide ) than 40 series .. so thought that the birf will be ok but not the inners ..
