The 3B has a pressure cap as the highest point on the engine. The stock radiator has no cap or holes apart from the inlet/outlet & drain plug.
A new radiator from Toyota is out of the question, and ideally I'd like something with a bit better cooling capacity. Various later models of Landcruiser radiators will fit, however they are all designed for an engine without its own pressure cap.
If a radiator with its own recovery cap was to be fitted, 1. is it possible & 2. how should this be gone about?
The cap on the radiator would be more or less an inch and a half lower than the engine cap.
My initial thoughts was to put a t-piece in the recovery hose, one going to the radiator cap and one going to the engine cap. After further consideration though I thought that when under pressure the coolant would overflow, not out of the engine cap, but out of the radiator cap, decreasing water levels until it was inline with the lower cap on the radiator. This would mean only the bottom 1/3rd of the radiator hose would have coolant going through it.
Then when it gets sucked back in it would take the path of least resistance, that being the one to the radiator filling level instead of right up to the engine level.
My other solution would be to block off the coolant recovery hose of the new radiator and just keep the overflow going solely to the water outlet.
Thoughts?
Thoughts?
