- Year
- 1984
- Vehicle Model
- 45 Series
- Location
- Bend, Oregon United States
- Mileage
- 132000
- Color
- White
I purchased this truck from a customer of mine about a year ago. I've become absolutely overwhelmed with work and with good conscience can't start this project before finishing the 10+ customer builds I've accepted
I'm into it 35K and would like near that.
The vehicle is a project but runs well and drives surprisingly amazing. Imported from the Netherlands with foreign dutch title and all import paperwork. I can get an Oregon title easily if need be. So far that's been on the back burner but should take less than a month or two with my dealer license.
12H-T Turbo Diesel engine - it runs very well with little to no smoke even when cold.
H55F transmission swapped
Disc brakes front
Power Steering
Kaymar Rear dual swing out bumper
Dobinson 2" suspension - complete with bushings, shackles, shocks, stabilizer etc
33x10.50r15 with new BFGoodrich KO2 tires
The cluster shows 213xxx KM (132,000 miles). Engine miles unknown
The frame is perfect, however the body needs help. It needs a new door and rust repair in most panels. Someone at one point took a grinder and spray paint to said areas. I have a good condition white and blue hood. I have the original bonnet as well, but replaced it with an early 40 bonnet with less rust. I also think it looks nicer.
Despite the body rust the floors are great with what I would consider only one hole under the clutch pedal.
The truck needs some electrical help, mainly a few gauges do not work. Glass is original with no cracks. The tie rods are new. The suspension, drivelines, brakes, etc all tight.
Located in Bend OR
5414200049
Disc brakes front
Power Steering
Located in Bend OR
5414200049
