bj42 clutch rlse. brn.
Southwestern Ontario
Hello,
I have recently bought a BJ 42, but has a B engine in it , and an H55 trans. My driveshafts have been altered.
I have not installed the trans yet as I am not sure of which clutch throw out bearing i should have. I purchased one from Toyota which I believe is the 4 spd bearing because it is larger than the one currently installed/pressed on to the cast piece with the "ears." (are these bearings special from Toyota?)
I also have 4 rebuilt/new injectors and new crush gaskets (2 per njector)
I am also wondering if there would be any difference in the glow systems between the B and 3B.
I'M
Sooooooo close to driving it !!!!
Cheers,
congrats in first time for your cruiser .. I thought you are so happy right now.
I'm not have much help to you in the clutch issue .. so when I do the clutch in my 2H-H55F combo I go with bearings to a bearings shop with the samples, and buy a koyo bearing.
gagnier said:
Hello,
I'M
Cheers,
i got your email, take the clutch bearing to BC bearing or Commercial bearing and they might be able to match it up.
the B is a manula glow and the 3B is a super glow (i like the manual better)
