Looking for a new set of alu wheels for my BJ-70. Was wondering what the stock back spacing is and what range of back spacing one can use? Thanks.
coldtaco said:Looking for a new set of alu wheels for my BJ-70. Was wondering what the stock back spacing is and what range of back spacing one can use? Thanks.
coldtaco said:I'm looking for a 255/85R/16 size, tall and skinny. I screwed up when I ordered my Marks gears and got the set with the "higher?" overdrive, rpms are way higher at highway speeds, so need to compensate without ordering a new set of gears and trying to sell these. Got any ideas? Don't want 15" wheels as they don't leave enought space between the rear break drums when you run in mud, the clearance is real tight but works.
M John Galt said:Is 'backspacing' and 'offset' the same measurement?
Between what two points is it measured?
For example if one wanted a wider track, how would the BS or offset change from the 3.5" standard LC wheel?
