So long text update.
Carb:
First off, if you haven't read Ed Cook's carb description in the Tech Links (
http://www.ih8mud.com/tech/carbinfo.php) you should.
I've been working on trying to identify the lean condition I am experiencing. Based on driving with one eye on the AFR gauge I think I have a course of action. My hot idle mixture is lean, so I can fix that with a screwdriver.
I still require some choke to run near stoichiometric while on the primary circuit. This seems to indicate that I need to change the air corrector jets to enrich this mixture. If I understand everything correctly, this requires smaller jets to reduce the air flow. It may also require a larger main jet.
Even with the partial choke, once the secondary opens it gets very lean >=18:1. First thing to do is spray down the secondary barrel with carb cleaner and see if is just some gunk. This will require a larger main jet and possibly a smaller air corrector.
The accelerator pump seems to be doing it's job. When I floor it, the AFR goes rich ~12.5:1 which is expected. I still need to try some WOT to see what the AFR is for a non-transient WOT.
Sliding Windows:
I've decided to keep the BJ42LX sliding windows and have an adapter made out of 16ga steel sheet. I will need to decided if I want to have the adapter welded to the frames or just adhere it using windshield adhesive.
I've drawn up the adapter and will be getting it cut soon.
Transmission/T-Case:
I've located a 4-speed transmission mated to an older 3-speed vacuum t-case, I'm going to pick it up this weekend. I'll need to track down a 4 speed nose cone or swap in the gear for the vacuum shift. I think the 4 speed nose cone will be easier.
Of course I'll still need a 4 speed bell housing to make this all work. I plan on keeping the 3-speed flywheel and clutch.
New Issues:
It seems I have a very slight drip from my rear diff cover (at least based on spots on the driveway). I'm going to clean up the diff with some simple green this weekend and see where oil may appear. May just need a new gasket or drain plug seal.
