I would just put a simple knuckle rebuild kit in right now along with wheel bearings
just to see. I have had bearings make noise before.
I would just put a simple knuckle rebuild kit in right now along with wheel bearingsjust to see. I have had bearings make noise before.
All day I have been waiting for you to reply, and now you have! Thanks. I am not sure what I am thanking you for, but sure, whatever.
I did a complete rebuild of the knuckles less than 8,000 miles ago, so I would think that the bearings are in good shape.
For now I think that I am going to put it back together, put more grease in the knuckle than was in there this time, and go wheel it again to see if I can make it make that sound again.
If it does it again I am going to get video and post it here for all you to see just what it is that I am talking about.
Oh s*** man......nothing silly about that. Kurt can hook you right up.
When you get a new one i would cut the bolt off both ends then drill it out then put your own bolt(threaded at both ends of course) then proceed....keeps from recurring
I got one from CDan, but I am not going to cut it off in hopes that it lasts long enough for them to be up for sale. I bought a Vortec and have it in the garage getting torn down and overhauled so that it is puuurrrrrrfect and puurrrty when it is time to put it in (late this summer I hope). At that point I will try to sell it to someone that needs it.
I actually mistyped my entry. My birfs had 325K on them when I removed them.
Mine had 350 k....yes i beat the dog snot out of minewow thats a lot of miles to put on a birfield. did you ever not drive it in 4wd?
wow another cruiser thats never been driven in 2wd. where do you guys live... the north pole?
maybe I'm the only one getting it
Hey Gunnar, is Randy doing your swap? or are you gonna try it yourself? You will be much happier with the Vortec.
Dynosoar![]()
I also took the brake backing plate and ground off the rivets that hold secured the brake line juction (flexble hose from the axle to the hard line that goes down to the caliper) and welded nuts to the inside and used bolts from the outside so that when I remove the calipers, I can take out those two bolts and remove the brake plumbing with it. This way I do not ever have to undo any brake lines whan I take apart the front hubs. Well worth the effort.
This post goes out to the Noobies.
It was a busted motor mount making the fan blade hit the fan shroud!And after all the time and trouble that I went thru to take apart the front end and check both birfields!
Well at least I know that they are ok.
Thanks to CardinalFJ60 for pointing me in the right direction![]()
