Bilstein Shock Compatability with AHC (1 Viewer)
Little Rock, Arkansas
Hi All,
I'll try to keep this organized:
Sitrep: All 4 Shocks need replacing on my 05 LX with AHC system that I want to keep
Problem: 4 new AHC compatible OEM shocks (48510-69127/ 48530-69145) will cost ~$1000 all told with taxes and shipping.
Question: Bilstein shocks (4600 series) are cheaper, but are the compatible with the AHC system?
Hi All,
They are not compatible. You must replace them with either new or used AHC shocks.
Why would you want to change the shocks on an AHC equipped truck? It doesn't have shocks like a conventional suspension system has. Suspension damping happens in the actuators, not in what looks like shocks. Have you read the AHC threads in here? If you did, you could change your username soon :)
I'll bet that your shocks don't need to be changed. I'll bet that your AHC neutral pressures need to be adjusted. Read:
Thanks for the reply! I had my AHC neutral pressures adjusted to be close to spec (the back were too high when the front were in line) but I was still disappointed with the ride so I went looking and found these. To my untrained eye it looks like 2/4 of these are blown and 1/4 is damaged pretty significantly. Anyone care to take a look and tell me if I'm wrong?
What pressures are you getting in the front and rear? Looks like they were definitely leaking. If they have subsequently been adjusted back to spec, that might just be residual oil. Consider cleaning it off and testing to see if it re-emerges. At the same time, check the fluid level and color in your AHC reservoir.
Have you checked how many graduations on the AHC reservoir your fluid moves from high-to-low? Harsh ride is frequently associated with shot accumulators. As an additional aside, consider checking your ball joints.
The most rusty part is the protective shield of the shock. Cut it off like this:
Clean and anti-rust treat
and put on a piece of plastic drain pipe as a shield. It will last much longer
Old and new:
