Why not weld the tower on? Is it something you think you might have to remove? Not worth it to go through the hassle of making it bolt on. Easy to remove and stronger by welding it. Ive had them on my truck for 20 years and haven't had to remove them yet. I believe I've replaced and repaired more things in and around that area than you ever will.
I considered welding them on, but in this position I’d have to remove the steering box, air compressor, and a bunch of other things to have the access needed to weld them on.Ford made them removable on 1-ton trucks longer than you've been wheeling, and they still make them. Why weld them when you can remove them with two bolts.
Clever… I could likely do something similar with mig wire (being it’s handy).I put a trailer hitch on swmbo's crv years ago, and the kit came with these little spring wire gizmos that you could thread a bolt into then you had a foot long wire tail you could poke in a blind hole and use the wire tail to pull the bolt through. Freaking handy. I kept them and I've used them a bunch of times since.
I bolted my shock towers on the front of my 40 too. Thought I might change my mind at some point. Happens.
Actually managed to find the wire things I was talking about.
Fish Wire for 1/2in. Diameter Bolts | #CUR58400 | Action Car and Truck Accessories™
With any towing setup, there is always the need for a few additional items. Though your trailer hitch and ball mount may be tough enough to haul that heavy load, they cannot properly tow without a few supporting players. Towing accessories are a practical addition to your rig that add the...www.actiontrucks.com
Just drill/tap those holes to whatever those bolts are, M12 or something. Done. No pissing around trying to get nuts or captive nuts in there.Clever… I could likely do something similar with mig wire (being it’s handy).
I’ll give that a shot if tacking a piece of bar stock onto it doesn’t work.
At the moment, the question is do I weld the nuts onto a backing plate and then a rod to position them… or just use two rods/bars?
That ship has sailed. I’ve already drilled it out to 1/2”. Easiest route now is just to use the nuts and call it a day.Just drill/tap those holes to whatever those bolts are, M12 or something. Done. No pissing around trying to get nuts or captive nuts in there.
The challenge is that I can’t see to reach inside the frame and see the outside at the same time. For extra strength I’m leaning towards tacking them onto backing plates and then using a bar to slide them into position. The backing plate would distribute the forces over more area than just using the flanged nuts they came with. Problem overkill, but the drivers side is only 1/8” thick.I also bolted mine on with some big ass “whatever” fit in the hole.
I was more worried about having to cut them off if reassembly revealed that my fu was off and somehow something didn’t fit back on troopy.
So ya, everything went back on and the towers are bolted to the chassis.
Trogdor (for those that remember) had the same towers attached the same way… nonissue as far as use/abuse.
Managed to fit a spanner inside the chassis to zip it all up. Triple jointed wrists helps, but doable.
Cheers
Crusty
Have you tried Napa or anywhere local before donating to the bezos space program (made in China)
Although, dealing with local can be a proper pain in the A55. “Island service” is its own animal.
Keep in mind, a set of OEM 555 tierod ends will run you nearly $200cad plus the ride for about any series.
YMMV
Cheers
Crusty
YMMV
Cheers
Crusty
