If you use the 2 bolt booster, you can re use your original master cylinder. Just pull it forward, replace the booster, and bolt back into place. No need to disconnect the brake lines and bleed. ( just to be clear, 2 bolt refers to where the m/c bolts to, not where it bolts to the firewall.) From recollection, the extension was about 30mmWhy 2 bolts, I thougt you need 4 bolts ? And what/howmuch do I need to extend ?
THX Bastian
