Ok, I’m going to go and retry my spare....I couldn’t get the darn thing to fit on my 2014 so I didn’t try on the 17. If I ordered the Ultraswing and didn’t actually need it.....LOL.
The big question is, can you get the spare back out? My spare should be a touch smaller than your's (265/70 r17) and I can't get it to fit.Ill try to get some photos, I had a local shop do all of the work for me (Apex Overland in NC), so I haven't even looked at the spare yet.
**Update** attached are some photos.View attachment 2096930View attachment 2096931View attachment 2096932
It hits both the inside edge of the hitch receiver and the sway bar. But not a big deal as I have ordered a spare tire carrier and I am planning to put an auxiliary fuel tank in the spare location.What part of the vehicle interferes with the fitment of the spare? I imagine some components have looser manufacturing and assembly tolerances than others. That may explain why some of you can fit a spare and others can't.
Thanks! These sound like logical solutions to resolving my concern.From what I've read in several posts, the O.D. of a 265/65R18 (or whatever size) may depend upon the manufacturer.
I'd suggest finding a tire you're interested in, look up the actual O.D. of the tire and then I believe you should be able to crawl under the rear your vehicle and you may be able to measure the available space between the tire and the rear bumper bracket. Then just add that to the diameter of your current spare and that should give you a rough idea of what you can fit under there.
Another option is that you can just take the spare off and leave it in your garage, drive to the tire shop of choice and ask them if you can try an unmounted (not on a rim) tire of the type and size you want, up in the spare tire space. Wear something you don't mind getting dirty, get the tire, get on your back, and just bench press it up into the spare tire space. If it fits unmounted, it will probably fit mounted.
I have told many people that I like the Falken better in every way except one than the KO2. I have run both of these on my F150. The Falken better in rain, snow, dry and also they wear great, way better than KO2. The only win I give the KO2 is I feel they look better. Also Falken are priced much better so go with Falken.I had ordered the KO2's but then cancelled when I started reading that the Falken Wildpeak A/T3W's are much better on ice due to a softer rubber. Getting them put on next week, went with 265/65/18's. From what I read, the KO2's are too hard and slip really easily on ice. The other thing that changed my mind is that it sounds like the A/T3W's are a bit quieter on pavement. Will primarily be using this vehicle for snowboard trips (Mammoth, Utah, etc), so wanted something that could work well on ice/snow and be fine for general all around use where I live (SoCal) -- don't want to have to use winter tires. Basically I was looking for the best all terrain that could work really well on snow and ice.
I'm in the process of trading my '12 T4R SR5 for an '11 GX460. What are the best (and largest) tires I can run on the stock setup? I have a 60 for actual off road adventures, this will be my dd. I prefer to have AT2's, but am open to better options. Thanks.
MJ
