Best source for in cabin vacuum gauge
thebigredrocker
On a stock 71 FJ40. Aisan carb, canadian carb with a ported base. Is there a prefered spot to plumb a vacuum gauge? Intake manifold, choke pull-off line or dizzy line?
Does it even matter?
Thanks
If you lack a 10mm port on the topside of the intake, the booster line is next best. That said, the 10/69-9/70 carbs offered a manifold vacuum port in the fuel bowl of the carb. It utilizes the hollow screw that comes up through the throttle body to secure the fuel bowl. Some people would argue that it is not true manifold vacuum at that point, but I consider it good enough for all my needs.
Best
Mark
www.marksoffroad.net
I did as Mark suggests. I teed into the line to the brake booster. Works great.
Booster works well for me to. Easy location to work on as well.
I am running a Holley. There is a vacuum port coming off the base of the carb on the firewall side. I run my gauge off it.
I used the port on the top of the intake
What are you going to use for a gauge? I just have a vac tester on magnet lol works well :)
May want to go nonPO of some sort
Thanks for the reply's fellas. I do have two nipples on my intake manifold. Vacuum transfer case hose and booster hose.
@65swb45
Is this the bowl mounted port you mentioned as acceptible?
Came off the intake on my trail truck
PO had cut a hole for the radio.... so that worked perfect
Gauge from Summit Racing
@JohnJL
The PO put those there. Guessing maybe he was a pilot or at least around airplanes:meh:. If he was an airplane mechanic, he definately didn’t pass any knowledge to his offspring:hillbilly:
Here’s the best explanation I’ve gotten so far:
My guess is that they were part of the PO's whimsical nature... My first '74 spent time as an airplane tug for his company at the San Antonio Airport (He said it pulled a DC9 once). It still has "fasten seat belt while seated" and "life vest in seat pocket" stickers on both sides of the dash.
