I have a a Princess Auto 10 gal pressure blaster, and it seems I use way too much abrasive compared to the surface area I'm blasting. I just went through one bag (50 lbs) of abrasive (recycled glass) and managed to do less than one third of my ARB bumper.
Here are the particulars:
1. Regulator is set to 95 psi (blaster manual says anywhere from 60-125 psi)
2. Compressor is a dual stage Ingersoll Rand rated at 100% duty and 14.8 CFM @ 90 psi
3. Nozzle is 1/8" (blaster manual states 1/8" nozzle requires a 4 hp compressor and 12 CFM @ 125 psi)
4. Abrasive is Opta recycled glass (20-30) grit?
I am only blasting an area no bigger than a nickel at any given moment, and I keep the nozzle tip about 6" away from the surface.
Any advice would be appreciated.
