Best Lift for my 45 pick-up
Prince George B.C.
In the future I think I'd might lift my 45, not much 2 to 4 inches. Spring over looks easy but I don't see many done this way. Your thoughts.
nuclearlemon
not an addict
Moderator
windy wyoming
"looks easy" and "done right" are two different things. with a lot of thought and some fabrication, they're not bad, but you need to consider if that's what you need for the type of wheeling you plan on doing.
65swb45
Elder Statesman
Supporting Vendor
I run a 2.5 in spring lift from an FJ40 on the front and two add a leafs [one long, one short] for each side in the rear. Seems to ride OK.
After I do the 4 speed conversion and the power steering, I will prolly move up one tire size and go to 4" FJ40 springs in the front, with a pair of custom made Alcans for the rear.
Hth
