Hello,
I am a volunteer physician in Southern Belize. We have two troop carriers that we use to get out to remote Mayan villages to see patients. This is our 2001:
We have been struggling with an uncontrollable front-end wobble at about 55km/hr that makes the truck unusable. Our maintenance man tried many things: tires, wheel balancing (they are split rims), and had the axles serviced at Belize Diesel (the Belize Toyota dealer). Apparently it wobbled coming home from the dealer. They didn't have any other ideas.
I brought an 80-series down and had spent lots of time on that forum in preparation and since. I had to re-build the axle for an inner seal leak, so with this (I hesitate to say) experience, I thought I would go for it. I got a re-build kit from Beno in the States including wheel and knuckle bearings, thinking this might be the problem.
I read up on the free-wheel hubs on this forum (though I certainly don't fully understand them at this point) and got everything taken apart today. Unfortunately (as I was hoping to find something grossly abnormal), everything seems good. The knuckles were nice and full with moly grease, no diff. oil leaking, all of the bearings seem fine, and I don't see obvious signs of wear on anything else.
I did, though, see a few things I didn't expect. First, my free-wheeling hubs don't look like the ones I have found on various posts or on the FSM exploded diagrams I have found:
Then, with it removed, there was only one snap ring on the end of the axle (the inner one, it is already off in the picture). I wondered if maybe the outer one is engaged as part of the FWH mechanism (?).
Finally, there was only one nut on the axle, not the thrust washer, adjusting nut, lock washer, lock nut that I was expecting. This is the nut:
It was right against the outer bearing:
From there in it was just like my 80-series.
So, is any of the above not right? If it is, does anyone have any other thoughts about my problem (with the vehicle, not the obvious one that I am in over my head!). With this vehicle out of commission we are really struggling, and our options are quite limited. Any ideas would be greatly appreciated.
Sincerely,
Bill Brown
Sincerely,
Bill Brown
