[FONT="][/FONT]
Thanks for all the stencil ideas and other comments.
Originall posted by wussypup
Awesome!
How are you planning on routing the air and power?
-Steve
Thanks. Actually I already have air and power on my old rack. The existing power comes up through the PS A pillar and also through a hole in the PS rear roof. The wires are fairly large to power the compressor which is in an aluminum box. The compressor runs to two six gallon tanks, also on the rack. The two tanks I plan on replacing with one 9 gallon tank. The old rack had three Hella 4000’s on it, so I might have to increase the wire size for the additional two lights.
As far as the air lines go, I can just run them from the tank to the cylinder control valve. BTW, the default position for the cylinder control valve is to keep the cylinders and covers closed. With regard to that, I drilled, counter bored, and tapped some rubber bump stops into the upright supports. (see picture)
Originally posted by bjowett
Love the fab work... excellent stuff!
Question, how fast does the guard flip up? I can see a big blop of pebble filled mud being pressed into the lens...
Good point. Right now I have the cylinder speed set to about one second. I have a 2 position, 4 way, 5 port 12v solenoid valve to control cylinder operation. To control cylinder speed for testing, I am temporarily using a flow control valve as seen in one of the pictures. If I would go with air cylinders, I would change that to adjustable control valve mufflers for simplicity.
That’s one of the little drawbacks with electric actuators. The speed would slow down for sure. To get a fairly powerful one or two, it would operate at about 4 tenths inch per second IIRC. With a 4 inch throw, it would take approx. 8 seconds to full open and close. Not that I’m in a hurry.
The reason I considered this mod was I had to climb up on the rack in the slush, mud, snow, and bugs, just to get the covers off to use the lights. Wimping out and trying to keep from having to wash my clothes in some puddle I came up with this idea.
Mot, I bet you have some lights that would look much better up there.
Oh, it just occurred to me for those that have never run lights up top. With my old setup I had to make a plastic visor kind of thing on the bottom to keep the lights from shining down and lighting up inside the dash. It was really bothersome because of their position on the rack. Thats why I made the covers flip down and not flip up, to block some of the light.
Bill
