I reassembled the gears and bearings, and I'm thinking something is wrong. There is considerable play from front to rear. In the photos you can see when i pull the shaft towards the rear, the gears seem to be aligned correctly. But when i push the shaft towards the front, the gears appear misaligned. If i use shims (speedo housing)to snug up the package they will push the gear assembly into the misalinged position. Any suggestions?
