Does anyone have a link or part suggestion for some excellent quality pre-cut battery cable connections for my 1994??
Like the other's have replied, I would make your own. Get the hydraulic crimper, which will do a way better job than the 'hammer' model. It give's you another reason to add a tool to your collection... I'd also suggest using an Anderson connector at the winch:
This will provide an access point for using jumper cables (after you make up a set, since you've got the crimper now...) without having to open the hood and fiddle with attaching the aggravating spring clamps.
I bought a bunch of cable from these guys:
TRYSTAR :: Custom Cable & Power Solutions. You can even get the cables custom printed. They did sell on eBay, but I don't see them having any items for sale currently. But, there are a ton of other cable sellers on eBay to choose from.
The connectors in the above pictures (not the Anderson connector on the winch) are all soldered and adhesive shrink tubed. If you want to go that route, you can purchase the terminals and the correct soldering slugs from:
Catalog They are less than 40 miles from me, and I've purchased a lot of different items from them. A properly fitted, soldered, and adhesive shrink tubed terminal isn't going to come loose. Terminal Supply can also make up custom cables, etc., to order.
