Badlands Apex 12k control box relocation
Broomfiled Colorado
Hi everyone! I just wanted to post this on here for anyone else that has purchased a Badland apex winch and is looking to relocate their control box. It took me quite awhile to figure something out and I just wanted to share what I did to help with anyone who is in the same predicament that I was in.
If you take a look at the control box for the Badlands winch you will find that it is big. Like similar footprint to your battery big. I initially cut into the valence below the grill hoping that the box would fit but unfortunately the transmission cooler did not allow me to slide my winch and bumper all the way in.
Assuming you only have the one battery you will need to relocate you windshield washer jug to the back of the engine bay. I purchased the Delta vehicle Systems kit, I think Slee has on as well. the control box will basically go into the area where the washer bottle was at. Now there is still some work to do. I basically cut the hell out of the control box with my grinder around the feet of the box. This allowed me to get it in flat ish on the inside of the passenger side fender. Using the existing threaded holes (one from the washer bottle and one probably for the other battery tray) I mounted the box there. I did need to tweak the bracket just a bit to get the right distance which is about 10 inches. Now the hardware I used doesnt look clean but as long as it sits tight I dont care lol. Essentially I needed some spacers to go in between the bracket and the inside of the fender. Me and my buddy found some random junk in his hardware drawer in his garage that got the job done.
Below is some photos of my make shift hardware and the actual mounting of the box
Once that was finally mounted the next step is of course getting it all wired up. The wires that come with the winch are like embarrassingly small. Its as if they think you're going to move the winch like a literal foot. I went to my local Oreillys and got a total of three five foot sections of 2ga wire and some terminal connectors. I also got some conduit for the wire as well. Once the terminals were crimped on the ends of the wires and the conduit was wrapped around each one I routed the wires from the control box down and under the frame rail, and then popping back out into my bumper to land them on the winch. With the three 2ga wires I did try running it behind the passenger side headlight but the coolant overflow would not sit down tight.
for the main power cable that one easily will run across the front of the rad behind the grill and to the battery. I will note the positive wire off the control box is just long enough to reach IF you don't use the disconnect switch. With the disconnect switch you will have plenty. The ground wire that comes with the winch is also plenty long to reach the ground lug on the winch.
Clean install. When I get around to a winch, that's the one I'm going to get and I'll probably emulate what you have going on here to a degree. Think there's anywhere to put it without having to relocate the reservoir?
Mine is currently zip-tied in between the washer bottle and air filter canister. I need to permanetize it like yours. My cables are long enough where it is now, barely.
I know a few people with that winch and they're all happy. Probably what I'd buy if I was shopping for a winch. That said, that box is ridiculous and I'll bet it could be made considerably smaller. Someone who works with plastic (paging @Outsane 😆 ) should take a look at that and see if they can't shrink it. I'd bet anything that if you opened that box up, it's probably mostly empty and just there for aesthetic reasons.
So I did think about taking the box apart completely and yeah the actual solenoid pack is tiny compared to the enclosure that it sits in. The reason I kept inside the enclosure is just to protect it and the buttons are integrated into the enclosure as well. Granted the solenoids would probably be okay if it wasn't in the enclosure.
Thank you. I was hoping that it would fit in-between radiator support and the battery but is was even too big for that. I also contemplated putting it behind the grill but it was too bulky for that even. A part of me thought of doing something crazy and putting it somewhere in the cab and running some long wires up front.
Now if you take the control box apart which I did do to help me brain storm, the solenoids/board is significantly smaller. If you went that route you may have to use a different power button for the wireless receiver since that button seemed to be a part of that enclosure. I'm sure if I spent enough time with it I could have figured out a way to get rid of that large enclosure entirely.
