2001LC
Those overhead DVD with player in rear cargo area, are notorious for parasitic drain on battery. (Google how to test for parasitic drain)
Under the dash on PS below glove box at far right are two (IIRC) inline fuses. One is always powered the other is IG key on powered. The red wire was always on in the 06LC I was working on. Do a parasitic battery drain test with that fuse in than again out.
forum.ih8mud.com
In above thread I was searching down aftermarket wires. I found the DVD was my draining battery while parked, and others have also. They are install here in the USA not at factory, is my understanding. You'll also see a way to remove the DVD player from rear, without pulling the whole side panel off. Easy once I figured it all out.
You can keep fuse in for kids to watch moves while on the road. Then pull out for over night parking.
Parasitic Battery Drain drop down DVD
I just found a picture from working on blower fan. Looks like this one cable with white tie is where you found fuse: That red/orange/black look the same as the right side connector in post #22. I would think one is ground, constant 12v and a switched 12v. I would pull the plug on the rear DVD...
