- Thread starter
- #41
Answers: Experts looked at my pistons. The "skirts" are scuffed and the pistons should be replaced. He said it's been running HOT! I told him about 8 years ago it overheated & hasn't gotten over 1/2 way since. Maybe I should buck up for a better guage? Maybe my cheap replacement water pump doesn't pump enough? I described the cylinders to him and he said they should be fine. I asked about blade/stone hone or ball (dingleberries, monkey balls) hone. He said ball hones are idiot proof (perfect for me! Ordered on Amazon 1"3-3/4" (95MM) Flex Hone 240 Grit Aluminum Oxide, $42). I also told him I plan on replacing the rod bearings, pistons, rings, but not the crank bearings, he said that's fine.
Here's a pic of the telescoping guage being measured by the caliper.
Notice the book, cylinder with Mark 1 3.7008"-3.7012", later says Max 3.7098". Thus, I put the caliper at 3.710 & made sure it stuck in the cylinders. Thinking through this, it is the most accurate method I had to check.
Questions: OEM or forged pistons? Guy at work said I should consider aftermarket pistons. JE pistons. They're website is complicated. I'll scour the MUD for advice. Cooling? I'm going to add an OEM thermostat & bring in radiator for check, can't afford an OEM water pump. Again, I'll scour the site for aftermarket cheaper one.
Next step. Finalize list of parts and spend money. Start cleaning EVERYTHING!
