oil pan
Good to hear
It's a nice feeling to hear a proper running engine isnt it?
Doing an oil pan?
I just did a new gasket and you may not need any tips but here's a couple things that might help just in case:
The oil pans can be difficult to remove ---carefully tap in a putty knife or wood chisel, etc from the side and it will work loose-- might give it a whack with a rubber mallet too
The thread holes come up through the block so you can shoot pen oil down into them. Be gentle with the bolts.
Gaskets might be advertised as 4 piece or one piece---I ordered a one piece after ripping the 4 piece---it was just the 4 piece glued together
clean surfaces really well
Here's a trick I had been taught in my teens and forgot, POSER reminded me---- and the reason I tore my 1st new gasket.
The holes will not line up perfectly so tie them in place with string
or yarn use a couple long bolts just to hang the pan in place. I tore the corner of my gasket trying to line up the bolt hole and it leaked. start the bolts and cut and pull the string out
Make sure the gasket goes into the journals properly all the way round at the front and back end as you tighten up . I put a little sealant in the journals too
I put in the front and rear bolts first getting the round part of the gasket into the journals, then the rest
let my mistake be your success!
