80 Rear Proportioning Valve
Go here first (from the tech page on this forum):
http://www.safari4x4.com.au/80scool/tech/brake.html
After reading this, you also need to make sure that the sleeves and bushings are not bound (just about every toyota rear I've seen is after a couple years). You change the proportioning curve if the pivots are stuck. You have fixed proportioning if the pintle valve in the unit itself is stuck.
As we proceed understand my disclaimer:
Toyota considers brake proportioning valve to be a non service item. Replace with new only. If in doubt, buy new.
To service, remove the arm pivot point at the axle. Lube the pivot pin with grease, this allows angle 'A' (in the tech article above) to remain constant throughout the range of travel. Before installing the pivot, make sure the rear prop valve pintle pin moves freely. Remove the boot on the valve and move the arm up and down. If the pin doesn't move, you can either remove the assembly (Mr. T says not serviceable, replace) and work the pin with WD40 or PB blaster. I normally soak the pin for a couple days, and it usually will work itself free. The problem doing this is that if it's got too much rust/crud, it can compromise the pintle seal. Hence the reason for R&R, not service. It's not cheap, and I've had good luck reviving many toyota and similar rear prop valves. My disclaimer: If in doubt, buy a new prop valve. What works for me, won't necessarily work for you.
The FSM gives the Adustment spec of 90mm for length 'A' in the tech article above. That is for a brand new truck, bone stock. If you have access to brake pressure equipment, you can really do a lot of work with the rear valve to get the most out of the rear braking for your given setup. As Jack pointed out in another thread, you always want front brake proportioning to exceed the rear. Rear brakes locking before the fronts under heavy braking loads, is a major no-no in terms of vehicle control. With test equipment, you want to have less brake pressure rear at ALL rear prop travel range. I won't give my personal targets, as I will only recommend factory procedure here, anything else needs a detailed knowledge of your specific truck and it's mod deviation from stock.
I had good luck deleting the Prop valve alltogether on my 4R and plumbed in a Tilton 7 position valve. In the 4R system the overrun (brake pressure not thru the valve) went into the right front brake line. I haven't looked beyond lubing and unsticking my rear prop valve on my truck, so I don't have further information on this mod specific to the 80.
On a lifted truck, you will need to compensate for lift with a lift bracket attached to the rear axle. Most lift kits supply these IME. Edit: If not, you *need* to know that your proportioning valve is always going to yield less braking force regardless of load than what Mr. T engineered (read: you are reducing total brake capacity, and adding to front brake wear/load.)
This Device affects Rear Axle Brake Capacity in a non locked CDL (off) driving mode. Prior to ABS activation it dictates the proportion of the Rear Axle Brake Force, for a given truck weight distribution compared to Front Axle Brake Force. Rear proportioning is usually presented as a % of front axle brake force. As a rule 70-80% is the maximum R:F braking force.
This Device affects Total Brake Capacity in CDL (on) mode driving in all brake force applications.
HTH
ST
Thats the first thing I've read from you that I completely understand. Now, how do I check to make sure my proportioning valve is actually proportioning?
Buck
HTH
ST
