Ha when did that happen?? Wonder what he moved into.He already sold/traded his LX700h that he did it too.
We are missing some weldments on the frame for the tank mounting straps; so I've started designing some hanger brackets that will bolt up as a substitute for the missing weldments. Aside from taking care of some other priorities, I'm also wanting for my sliders from Slee to arrive before I move forward. I want to make sure the fuel tank bracket won't conflict with the slider mounting.I haven't been able to find a oem aux fuel tank for the hybrid models. Hoping once the 300 series gr sport with hybrid system comes out in Australia, parts diagram would be readily available and easy swap in.
In watching the video, towards the end as he’s lowering the vehicle, it looks like the spare tire might be lowered somewhat. Like it now hangs a bit lower.This is my truck - picked it up today. Next step is to fill both tanks and see that the siphoning system works - hope it does, otherwise I will install an inline fuel pump.
Good idea. I’ll get with my technician and figure out any and all options and report back. I seem to remember that his day off is Thursday but I’ll swing by the dealership.I wonder if techstream has a way to modify the fuel expected mileage. Similar to ones that comes from factory with
Really intriguing idea!An alternative idea is to use a fuel signal integrator.
The OEM aux tank has a secondary fuel level sender unit which is direct fed to the ECU. In my investigation the wiring harness for the secondary fuel sender unit is not installed in the truck. The next step (whenever I get around to it) will be to check the ECU the signal goes back to for the same pin out as the international truck. In which case it may be as "simple" as running new wiring to the ECU.
An aftermarket fuel integrator module may be able to take both sender unit signals and appropriately scale and output a signal the USDM ECU will like. I've not gone very far with the aftermarket option research at this time.
Not sureI'm assuming because the aux tank is only 30L, that it's being triggered by (a) instead of A?
Not sure
More to come over the coming days
Just Aux and that is what I’m watching now.I just read your account on the other thread. If you drove 265 miles since fill-up, you should definitely not be on full for the primary tank. Did you get their extended range primary as well, or just the aux addition?
He traded for a F250 for towing reasons if im correct..Ha when did that happen?? Wonder what he moved into.
