Unless you go part time t-case and locking hubs, do NOT do an auto locker in the front.
What has been said is correct. I used to drive a 69 Chevy 4x4 with limited slip F/R, locking hubs, 4 speed, and 375 HP.
When in 4WD, hubs locked in, all 4 wheels turn the same. When I was in greasy mud I could NOT turn a corner. I had to burp the throttle to rock the truck and create articulation in order to turn. This would be the same on wet rocks. I had an incident on 100% ice covered roads that as I came downhill into a joined 4 lane road, fortunately, there was no traffic, because my momentum carried me into a slight right turn and I continued to pirouette a full 360 just due to rotational forces and I did it about 35 MPH and about 1/4 miles. It was a beautiful thing, but I was fortunate that no one else was there and I didn't hit anything. I tried locking the brakes, I locked the brakes, then put it in reverse, and dumped the clutch to almost WOT the get the tires spinning backwards, all trying to make it do something, all to no avail. Eventually, I came to a stop, then I gently started again ang idled my way to the next corner. I then placed it into 2WD when I came to a corner so I could steer.
As I've gotten much older and a little wiser, since I have the opportunity to do it all again, except this time with a Land Cruiser, I will go selectable locker in both front and rear. It gives me the best of all worlds and I can turn them on or off when I want. I could still do PT T-Case and locking hubs if I wanted, but I really like the highway stability the AWD gives during daily driving. I will choose an electric locker so I don't have all the other added hardware of an air tank and solenoids and all that.
Buy once, cry once.
That was a different beast, but I could pull a loaded dump truck or semi with that truck. It had low enough gears and enough HP that if I could get the traction, it could do amazing things. My LC is a much better vehicle, but my needs have changed. I no longer need to pull farm wagons to and from the grain elevator 35 miles each way. Oh, it also got 14 MPG on the open highway on a carbureted engine. 12 MPG whether I was pulling a trailer or working it hard. My LC gets 11.5 and only has 190 HP or whatever it is.
