Hello
I know this has been asked and I found it myself when searching. Below are the directions I found on how to get the doors to lock and unlock based on a preference you choose.
I have a 2002 LX470. None of these options below worked. I have been trying for two days. I've done everything listed. I CANNOT get it to work. Is my vehicle too old for this?
Also, I found many people can roll down windows and sun/moon roof with the push of a button on keyfob remote. I cannot do that either.
What am I missing?
Thanks in advance.
Automatic door locking and unlocking functions
AUTOMATIC DOOR LOCKING
You can select the following functions:
- Locking linked with the shift position
All doors are automatically locked when the selector lever
is moved out of “P” position
- Locking linked with vehicle speed
All doors are automatically locked when the vehicle speed
goes above about 20 km/h (12 mph).
You can set or cancel the automatic door locking
functions:
Be sure to apply the parking brake when performing the
following operations.
To select the locking linked with the shift position:
1. Close all doors and turn the ignition switch to the “ON”
position.
2. Shift the selector lever to the “P” position.
3. Within 10 seconds of turning the ignition switch to the “ON”
position, press and hold the driver’s side power door lock
switch in the lock position for 5 seconds and then release.
The doors will be locked and unlocked to indicate that the
function is set.
To cancel the function, do the above operation again.
To select the locking linked with the vehicle speed:
position.
2. Shift the selector lever from “P” to the ”N” position.
function is set.
AUTOMATIC DOOR UNLOCKING
- Unlocking linked with the ignition switch
All doors are automatically unlocked when the driver’s door
is opened within 10 seconds after the ignition switch is
turned to the “ACC” or “LOCK” position, or the key is
removed.
- Unlocking linked with the shift position
All doors are automatically unlocked when the selector lever
is moved to “P” position.
You can set or cancel the automatic door unlocking
functions:
To select the unlocking linked with the ignition switch:
position.
2. Shift the selector lever from “P” to the “N” position.
switch in the unlock position for 5 seconds and then release.
function is set.
To select the unlocking linked with the shift position:
position.
function is set.
What am I missing?
Thanks in advance.
functions:
position.
function is set.
position.
function is set.
removed.
functions:
position.
function is set.
position.
function is set.
