ERNRAM
- Vehicle Model
- 40 Series
- 45 Series
- 55 Series
- Location
- Array
Free.... 1F engine
Block casing is 11411-60030 with a date of Feb 1, 1971
Head casting is 60031 with a date of Jan 28, 1971
It was pulled out of a 1968 FJ40. I ran well when i pulled it out and even compression tested it
110-115-120-120-120-145
I dropped the pan to see the overall condition and other than a few of the old style cotter pins that are on the rod bolts at the bottom of the panel it looked good. I checked the rod bearings and again the normal wear. Same with the crank. I reassembled the bearing with assembly lube and put all the caps back on. Dont think i torqued them down. Also looked at the oil pump and looked good. Did not torque down the the oil pan bolt or pipe lines.
It had a leaky frezze plug and i knocked out the 2 on the side and one in the back and cleaned it out .
I bought the replacement freeze plugs. I need to find them but they are free with the new valve cover bolts. I may have a new head gasket for it i bought in case. Again free with the pickup.
Eventuallyfound a strong 2F, thus the need to let it go.
North east Austin area.
Thanks
Ernie
Thanks
Ernie
