I used the 60 bucket to start with. The clutch and brake are all part of one piece in the 60, and they are too close together to use in the 80. I cut the clutch portion off and welded in a little bracing, but I knew it was too weak when I did it. The 80 uses two separate pieces, I could order them but it would be $200. Once I get the pattern figured out it shouldn't be too hard to make them out of some 1/8" plate.
just noticed your sig line...have you had aussie locker for a while? if so what's your experience with them (on and off road)
You run aussie lockers in the front and back on full time 4wd?
