So some creep attempted to steal my cruiser and the steering lock and ignition barrel are broken. The car is immobilised.
1. First thing is to get the car running. I don't seem to be able to turn the key to ACC to remove the barrel so I'm considering hacksawing through the steering lock rod so I can remove the key barrel and housing and then unscrew the ignition switch. Any other bright ideas before I get medieval on the car ? Maybe the lock can be drilled or forced into ACC?
2. I'm going to need to get a new steering lock assembly and ignition key barrel. Does anybody have the part numbers? (I'm in Australia, not sure if there's different RHD and LHD versions)
3. Can anyone recommend a mechanic in Melbourne, Australia (I'm northside)? I'm new to Landcruisers and it's looking tricky to repair myself, although doable.
Cheers
Cheers
